TwinTurbo.NET: Nissan 300ZX forum - 100 or 4.7
100 or 4.7
gbeto
on May 19, 2012 at 1:17 PM
Pretty much any bright red LED will work along with a 1k or
posted by jzack
on May 18, 2012 at 09:00 PM
I found some 100ohms and 4.7kohms resistors from a past project, and an array of 5 white leds of unknown voltage, if there is aa difference in voltage will it mess the ecu?
Injector problem
gbeto
14:19:07 05/17/12
Check continuity though the harness to the ECU.
Draker (Eugene, OR)
17:19:39 05/17/12
O-scope or Noid Lights
OverZealous (CT)
17:21:10 05/17/12
looking into this noid light.
gbeto
17:59:56 05/17/12
FYI - Just a simple LED with a resistor will let you run
jzack
22:28:51 05/17/12
Re: FYI - Just a simple LED with a resistor will let you run
gbeto
00:01:50 05/18/12
jzack
21:00:31 05/18/12
100 or 4.7 -
gbeto
13:17:39 05/19/12
Re: 100 or 4.7
gbeto
13:20:51 05/19/12
Might be able to use AC Voltmeter if you get smart
OverZealous (CT)
17:25:21 05/17/12
no the wire.
gbeto
14:51:49 05/20/12
Check the PTU
OverZealous (CT)
20:27:28 05/21/12
i meant
gbeto
01:05:11 05/23/12
